I am pretty sure if you use the pre-cooling tab (not heat rejection), then the cooling towers take care of the load before the chillers. Careful with the outdoor wetbulb temperature input though. Emir
I am pretty sure if you use the pre-cooling tab (not heat rejection), rejection) then the cooling towers take takes care of the load before the chillers. Careful with the outdoor wetbulb temperature input though. Emir
