The measure you are looking at is an old EnergyPlus measure, that pre-dates PV support in OpenStudio. That is fine, it still works, but this post shows how to add PV directly in the SketchUp plugin .
In both cases PhotovoltaicPerformance:Simple is used.
If you want to change the inverter efficiency you can change this string or expose an argument for it in the existing measure you are using.
    ElectricLoadCenter:Inverter:Simple,
    Simple Ideal Inverter,   !- Name
    pv_script always On,               !- Availability Schedule Name
    ,                        !- Zone Name
    0.0,                     !- Radiative Fraction
    0.95;                     !- Inverter Efficiency
Battery storage isn't in OpenStudio, so you would need an EnergyPlus measure for that.
used. If you want to change the control inverter efficiency or add battery storage, you can change this string or expose an argument for it in the existing measure you are using.
    ,                        !- Zone Name
will have to write a new EnergyPlus measure. Battery storage isn't currently available in OpenStudio, so you would need an EnergyPlus measure for that.OpenStudio.
In both cases PhotovoltaicPerformance:Simple is used. . If you want to control inverter efficiency or add battery storage, you will have to write a new EnergyPlus measure. Battery storage isn't currently available in OpenStudio.
