The OpenStudio Radiance measure should be the last one in your measure workflow. Add the meter first, then run the Radiance measure. The resulting idf and outputs should play nicely with your requested reporting measures, with the caveat that the Radiance graphical output is not easily accessed via reporting measure (the energy savings and new lighting schedules are, however).
