As a start, running the 'Space Type Report' from the Sketchup plugin (Extensions > OpenStudio User Scripts > Reports > Space Type Report) will get you a csv file with Building-, Story-, Space Type- and Space-level information including areas, Thermal Zones, and internal loads. It doesn't have anything about surfaces or constructions, but could help you get familiar with querying the model and outputting results. You can find the ruby file in C:\Program Files\OpenStudio 1.11.4\Ruby\openstudio\sketchup_plugin\user_scripts\Reports
As a start, from the Sketchup plugin running the 'Space Type Report' from the Sketchup plugin (Extensions > OpenStudio User Scripts > Reports > Space Type Report) will get you a csv file with Building-, Story-, Space Type- and Space-level information including areas, Thermal Zones, and internal loads. It doesn't have anything about surfaces or constructions, but could help you get familiar with querying the model and outputting results. You can find the ruby file in C:\Program Files\OpenStudio 1.11.4\Ruby\openstudio\sketchup_plugin\user_scripts\Reports
