The period where the heat loss is zero is when the heat gain is non-zero and vice versa. I think you'll need to use both of those variables to get to a balance of energy flows.
The period where the heat loss is zero is when the heat gain is non-zero and vice versa. I think you'll need to use both of those variables to get to a balance of energy flows.non-zero.
