As the name implies, Ideal Loads Air System is ideal. Refer to the Input/Reference guide for more information: ZoneHVAC:IdealLoadsAirSystem
This component can be thought of as an ideal unit that mixes air at the zone exhaust condition with the specified amount of outdoor air and then adds or removes heat and moisture at 100% efficiency in order to produce a supply air stream at the specified conditions. The energy required to condition the supply air is metered and reported as DistrictHeating and DistrictCooling.
100%efficiencyefficiency in order to produce a supply air stream at the specified conditions. The energy required to condition the supply air is metered and reported as DistrictHeating and DistrictCooling.
As the name implies, Ideal Ideal Loads Air System is ideal. Refer to the Input/Reference guide for more information: ZoneHVAC:IdealLoadsAirSystem
