@Morteza, there is an existing issue related to the OpenStudio intersect method. You seem to be hitting that. I was able to reproduce it with the model you sent, but I was also able to get it to run without hitting this error. I didn't do anything different one time vs. another. I'll email that file back to you. It is a 1.11.3 file vs. 1.11.0. Space 101 needs some minor repair, you need to re-draw an edge in SketchUp to crease surfaces to close to holes in the exterior roof surfaces, small glitch in the intersect.
