Looks like the issue, which was related to forward translation of daylighting control objects, has been fixed. You should be able to download OpenStudio 1.11.4 sometime next week, that will have this fix.
To fix this now with your current installer, you should be able to change the "Lighting Control Type" from "None" to "Continuous" for all of the daylighting control objects. You can access this through the inspector in the SketchUp plugin.
