See this question for code and instructions to write a quick measure that will display results in IP units. The measure also makes EnergyPlus output delimited, HMTL, and XML result files.
OpenStudio doesn't create the OutputVariable CSV file but you can run the out.idf file through EnergyPlus to create it. To view these I'd suggest taking a look at DView which is nice for viewing 8760 data in CSV format.
OpenStudio doesn't create the OutputVariable CSV file but you can during an EnergyPlus run so you'll have to run the out.idf file through EnergyPlus to create it. To view these I'd suggest taking a look at DView which is nice for viewing 8760 data in CSV format.
OpenStudio doesn't create the OutputVariable CSV file during an EnergyPlus run so you'll have to run the To view out.idf file through EnergyPlus to create it. these your results I'd suggest taking a look at DView which is nice for viewing 8760 data in CSV format.
See this previous question for code and instructions to write a quick measure that will display results in IP units. The measure also makes EnergyPlus output delimited, HMTL, and XML result files.
To view your results I'd suggest taking a look at DView which is nice for viewing 8760 data in CSV format.
See this previous question for code and instructions to write a quick measure that will display results in IP units. The measure also makes EnergyPlus output delimited, HMTL, and XML result files. To view your results I'd suggest taking a look at DView which is nice for viewing 8760 data in CSV format..
See this previous question for code and instructions to write a quick measure that will display results in IP units. The measure also makes EnergyPlus output delimited, HMTL, and XML result files. To view your results I'd suggest taking a look at DView.
