I assume you're talking about EnergyManagementSystem (If so, please tag your question with ems).
I see two ways:
- You just need to define actuators for that because you don't need to have several programs... All can be defined in the same one.
- If you want to do it at different calling points, then it is a valid point to have multiple programs and then yes you need to define it as a sensor as well
