@cadm0nkey make sure you are using the 64bit installer of SketchUp vs. the 32 bit installer. Also SketchUp 2016 is the preferred version, so you can un-install earlier versions. If you didn't already have the 64bit version installed, run the OpenStudio installer again after installing the 64bit version. Also can you let me know what version of mac OS you are on? It will help us to try and reproduce what you are seeing.
If that doesn't work this thread shows you how to manually copy the plugin files from the installer to SketchUp plugin's folder.
[Update - Mac Screenshots] image description This is where the Installer puts an extra copy of the plugin
image description This is where you need to copy the plugin to.
Then quit and restart SketchUp.
If that doesn't work this thread shows you how to manually copy the plugin files from the installer to the SketchUp plugin's folder.
@cadm0nkey @cadmOnkey make sure you are using the 64bit installer of SketchUp vs. the 32 bit installer. Also SketchUp 2016 is the preferred version, so you can un-install earlier versions. If you didn't already have the 64bit version installed, run the OpenStudio installer again after installing the 64bit version. Also can you let me know what version of mac OS you are on? It will help us to try and reproduce what you are seeing.
