Feel free to adapt the following code, it'll give you some training on measures too! I'd personally not create an actual measure for this, I'd just open a terminal window and do some interactive ruby on my model, but that's just me.
# If interactive, load model
path = 'C:\mymodel.osm'
translator = OpenStudio::OSVersion::VersionTranslator.new
ospath = OpenStudio::Path.new(path)
model = translator.loadModel(ospath)
if model.empty?
raise "Path #{path} is not a valid path to an OpenStudio Model"
else
model = model.get
end
# Find the north walls, with a big tolerance here.
between_deg = -25
until_deg = 25
# Conversions to SI units
between_rad = OpenStudio::convert(between_deg,"deg","rad").get
until_rad = OpenStudio::convert(until_deg,"deg","rad").get
# Construction: adapt to grep the construction you actually need
construction = model.getConstructionByName("North Construction").get
model.getSurfaces.each do |surface|
# Find exterior walls only
next if surface.outsideBoundaryCondition != "Outdoors"
next if surface.surfaceType != "Wall"
# Filter on azimuth: OpenStudio works CLOCKWISE (different from classic trigonometry), and returns it in radians
# Also doesn't take care of the Building North Axis, it'll be in your original drawing (that's usually easier anyways)
# If you want the north wall: 0, east: Pi/2, south: Pi , west: 3*Pi/2
# Filter on azimuth
azimuth = surface.azimuth
# Case where start point was negative
if between_rad > until_rad
next if (azimuth > until_rad) && (azimuth < between_rad)
else
next if (azimuth < between_rad) || (azimuth > until_rad)
end
# Assign the construction to the surface
surface.setConstruction(construction)
puts "Assigned construction to #{surface.name} which has an azimuth of #{OpenStudio::convert(azimuth,"rad","deg").get} degrees"
end
if model.empty?
else
model = model.get
end
between_deg = -25
until_deg = 25
# Filter on azimuth
else
end
end
between_deg = -25
until_deg = 25
# Filter on azimuth
else
end
end
between_deg = -25
until_deg = 25
# Filter on azimuth
else
end
#surface.setConstruction(construction)
end
Feel free to adapt the following code, it'll give you some training on measures too! I'd personally not create an actual measure for this, I'd just open a terminal window and do some interactive ruby on my model, but that's just me.too!
between_deg = -25
until_deg = 25
# Filter on azimuth
else
end
end
