Your Controller Water Coil 2 applies to a cooling coil and is correctly set to be Reverse Action, so that's not the problem.
The problem is :
**   ~~~   ** Controller temperature setpoint = 15.82 [C]
**   ~~~   ** Controller sensed temperature = 16.13 [C]
Your loop temperature is higher than the setpoint, that's what you should investigate.
