Taking a step back, I don't think you can successfully run a model with thermostats but without HVAC systems. You can turn on ideal air loads for all zones which should deactivate any thermostat schedules associated with the zone and eliminate the error.
If your model has a lot of zones you can use the measure Enable Ideal Air Loads For All Zones to loop through all the zones and do this for you. I do this to check for geometry errors before adding HVAC systems.
If your model has a lot of zones you can use the measure Enable Ideal Air Loads For All Zoneswrite a measure to loop through all the zones and do this for you. I do this to check for geometry errors before adding HVAC systems.
Taking a step back, I don't think you can successfully run a model with thermostats but without HVAC systems. You can turn on set ideal air loads on for all zones which should deactivate any thermostat schedules associated with the zone and eliminate the error.
If your model has a lot of zones you can write a measure to loop through all the zones and do this for you. I do this to check for geometry errors before adding HVAC systems.
Taking a step back, I don't think you can successfully run a model with thermostats but without HVAC systems. You can You'll need to set ideal air loads on for all zones which should deactivate any thermostat schedules associated with the zone and eliminate the error.
Taking a step back, I don't think I'm not sure you can successfully run a model with thermostats but without HVAC systems. You'll I think you'll need to set ideal air loads on for all zones which should in order to successfully run your model. This will deactivate any thermostat schedules associated with the zone and should eliminate the error.
Taking a step back, I'm not sure you can run a model with thermostats but without HVAC systems. I think you'll need to set ideal air loads on for all zones in order to successfully run your model. This will deactivate any thermostat schedules associated with the zone and should eliminate the error. If your model has a lot of zones you can write a measure measure to loop through all the zones and do this for you. I do this to check for geometry errors before adding HVAC systems.
Taking a step back, I'm not sure you can run a model with thermostats but without HVAC systems. I think you'll need to set ideal air loads on for all zones in order to successfully run your model. This model which will deactivate any thermostat schedules associated with the zone and should eliminate the error. zone. If your model has a lot of zones you can write a measure to loop through all the zones and do this for you. I do this to check for geometry errors before adding HVAC systems.
