The thermostat should have both a heating and cooling schedule. If you delete the thermostat the error should go away.
Normally the OpenStudio app should delete the thermostat associated with a zone if the schedules are removed.I'm wondering if that didnt happen in your case?
The easiest way to delete this thermostat if you can't see it in the stand alone app is to open the model in SketchUp plugin and open the inspector (looks like magnifying glass with OS icon in it).
We do have some unused thermostats in our templates but I think they are all valid.
