I might be misunderstanding the question, but you could add an AvailabilityManager:OptimumStart to your air loop to control it and then request the Output:Variable
called Availability Manager Optimum Start Hours Before Occupancy
to see the timeseries data of the starting points for each day. Not sure what output file jEPlus+EA exports by default, but the data will be in either .eso, .csv, or .sql file.
