ok i made some test runs and here's what i found in case anyone experience the same problem.
BaseSys12 is the computer room unit per T-24 baseline system map. In the Design Case we have split system heat pump serving those electrical rooms. In the Design Case, the heat pump heating coil was input as "none". I changed it to heat pump, then put a heating capacity of 1. When I rerun the model, the error is gone.
