I assume you have to compare two models (with and without atrium?). You can add daylight reference points (maximum two) to study daylight savings. In Daylighting:Controls object, you have to input required lux level and lighting control type. By doing this, you will be able to compare lighitng energy consumption for both models.
Please see THIS, explaning how to add dayligting control objects by using OpenStudio.
