If your model is located at C:\MyPath\model.osm
, go in the folder C:\MyPath\model\run\6-UserScripts
(sometimes the number can be different than 6) and then poke around to find the right .html file.
It's likely to be inside a mergedjob-X
since it's a reporting measure and by default there's already the official openstudio one.
If your you model is located at C:\MyPath\model.osm
file. It's likely to be inside a mergedjob-X
