You can use the Preprocessor WeatherConverter (EnergyPlusV8-5-0\PreProcessWeatherConverter) that comes with EnergyPlus.
Load the file, select as output format "Statistics Report on Input File"
You can use the Preprocessor WeatherConverter (EnergyPlusV8-5-0\PreProcessWeatherConverter) "WeatherConverter" that comes with EnergyPlus.
Load the file, select as output format "Statistics "Statitics Report on Input File"
