The OpenStudio Results are produced by a measure that gets values from the EnergyPlus results, so check the Lighting Summary report there for the real values.
It looks like the measure is incorrectly doing a conversion here, which may be happening if you're converting the results to IP units.
FYI @David goldwasser
The OpenStudio Results are produced by a measure that gets values from the EnergyPlus results, so check there for the real values. It looks like the measure is incorrectly doing a conversion here, which may be happening if you're converting the results to IP units.units.
The OpenStudio Results are produced by a measure that gets values from the EnergyPlus results, so check there for the real values. It looks like the measure is incorrectly doing a conversion here, which may be happening if you're converting the results to IP units. .
