To get a fake fan to use no energy, set the fan's Pressure Rise to something very small.
It turns out the rather than actuate the fan, it works better to control AHU airflow with the actuator on the air terminal unit, called “AirTerminal:SingleDuct:Uncontrolled” with the control type called “Mass Flow Rate.”
Instead of sensing a "zone" output, you can set up the sensor on a the zone's air node, which will have the wetbulb.
