Like for the ...Supply Air...
and the ...Zone...
output variables there are also a set of ...Outdoor Air...
output variables for the ideal air loads system. You can use that to check the energy/rates for outdoor air.
OS leaves all the parameters in the IdealLoadsAirSystem
object to defaults, and I don't believe you can change anything in the GUI, so you'll have to write a measure. The default for the outdoor air parameter is to not have any outdoor air which would explain the lack of difference you're seeing.
