Maybe the ISO 13790 can help you to decide.
"In particular you have not to dived a space in more thermal zone if:
  1. Set-point temperatures for heatingcooling of the spaces differ by no more than 4 K;
  2. The spaces is serviced by the same heating systeme (if any) and the same cooling system (if any);
  3. At least 80% of the floor area are serviced by the same ventilation system;
  4. The ammount of ventilation (in cubic metre per square metre of floor area per second) differs by not more than a factor of 4 within 80% of the floor area."
"In "*In particular you have not to dived a space in more thermal zone if:
  4. The ammount of ventilation (in cubic metre per square metre of floor area per second) differs by not more than a factor of 4 within 80% of the floor area."area.*"
"*In particular you have not to dived a space in more thermal zone if:if
  4. The ammount of ventilation (in cubic metre per square metre of floor area per second) differs by not more than a factor of 4 within 80% of the floor area.*"
"*In decide. "In particular you have not to dived a space in more thermal zone if
  1. if 1. Set-point temperatures for heatingcooling of the spaces differ by no more than 4 K;
  2. K; 2. The spaces is serviced by the same heating systeme (if any) and the same cooling system (if any);
  3. any); 3. At least 80% of the floor area are serviced by the same ventilation system;
  4. system; 4. The ammount of ventilation (in cubic metre per square metre of floor area per second) differs by not more than a factor of 4 within 80% of the floor area.*"area."
