The 2009 ASHRAE Fundamentals Handbook Chapter 14 on Climate Design Information will explain the use of these weather data and the terminology.
This document explains that the DB=>MWB is used for sizing chillers or HVAC systems (pg 14.6), WB=>MDB is used to size cooling towers, evap-coolers, and ventilation systems. The DP=>MDB data is used for sizing dehumidification systems. And finally, Enth=>MDB is used for sizing based on infiltration and/or ventilation.
The 2009 ASHRAE Fundamentals Handbook Chapter chaper 14 on Climate Design Information will explain the use of these weather data and the terminology.
The 2009 ASHRAE Fundamentals Handbook chaper 14 on Climate Design Information will explain the use of these weather data and the terminology.
This document explains that the DB=>MWB is used for sizing chillers or HVAC systems (pg 14.6), 14.5), WB=>MDB is used to size cooling towers, evap-coolers, and ventilation systems. The DP=>MDB data is used for sizing dehumidification systems. And finally, Enth=>MDB is used for sizing based on infiltration and/or ventilation.
