There is nothing special about a cooling setpoint schedule vs any other schedule. It is just a matter of setting the Schedule:File object to grab the correct column of data beginning at the correct row. Note that the same schedule file can have multiple columns of data representing different schedules. If you are having trouble with the file generated by Honeybee/Ladybug (or any other interface, for that matter), I would suggest exporting or copying the raw files out to a side folder and run with EP-Launch so you can troubleshoot. It is also helpful to use Output:Variable,*,Schedule Value to report out the schedules to be sure you are getting the numbers you expect, especially when using an automated workflow. As @Archmage noted, it appears that your values do not align with your column headings.
