First, you can enable DCV in OpenStudio:
- On the AirLoop, click the "Control" button at the top of the screen.
- Click the Demand Control Ventilation switch to "On." (In E+, this corresponds to setting the
Controller:MechanicalVentilation
fieldDemandControlVentilation
to Yes) - On the AirLoop, click the "Layout" button at the top of the screen.
- Click on the OutdoorAir System
- Set the 'Minimum Outdoor Air Flow Rate' in the
Controller:OutdoorAir
to 0. Otherwise the DCV won't be able to drop the flow rate.
For debugging, I suggest requesting detailed timeseries outputs and graphing them in ResultsViewer.
