If you trying to find out the contribution of carbon dioxide emissions from the building to the environment, you should take a look at InputOuputReference for the following objects:
If you are trying to track emissions within the building used for demand controlled ventilation and indoor air quality there are many more inputs. You should take a look at the InputOutputReference for the following objects:
- People
- GasEquipment
- Controller:MechanicalVentilation
- Controller:OutdoorAir
- ZoneControl:ContaminantController
As well as:
- ZoneHVAC:IdealLoadsAirSystem
- ZoneAirContaminantBalance
- ZoneCapacitanceMultiplier:ResearchSpecial
- ZoneContaminantSourceAndSink:CarbonDioxide
- ZoneContaminantSourceAndSink:Generic:Constant
- ZoneContaminantSourceAndSink:Generic:CutoffModel
- ZoneContaminantSourceAndSink:Generic:DecaySource
- ZoneContaminantSourceAndSink:Generic:Deposition-RateSink
- SurfaceContaminantSourceAndSink:Generic:Pressure-Driven
- SurfaceContaminantSourceAndSink:Generic:Boundary-LayerDiffusion
- SurfaceContaminantSourceAndSink:Generic:Deposition-VelocitySink
Other objects may impact the balance of carbon dioxide in the zones such as any of the Zone Airflow group of objects and the AirflowNetwork:* objects.
If you trying to find out the contribution of carbon dioxide emissions from the building to the environment, you You should take a look at InputOuputReference for the following objects:
If you are trying This does not include the fields related to track emissions within the building used for demand controlled ventilation and indoor air quality there are many more inputs. You should take a look at the InputOutputReference for the following objects:quality.
- People
- GasEquipment
As well as:
