In the chiller settings, see the bottom of the image, the condenser type, it can be setup as air cooled, water cooled and etc. If it is air cooled, you need remove the condenser water loop if there is one. image description
In the chiller settings, see the bottom of the image, the condenser type, it can be setup as air cooled, water cooled and etc. If it is air cooled, you need remove the condenser water loop if there is one. image descriptionone.
