You have a syntax error in the configuration file for the entry SimulationStart { Command = ....
GenOpt returns the error message
Command string : 'cmd /C ""C:\Users\SambuKS\Desktop\EP_Calibration_MinOA\GenOpt\Calib.bat" "Calib" "GBR_Birmingham.035340_IWEC" "C:\EnergyPlusV8-4-0\" "Measureddata60min_2012.txt""'
which shows that you have only one backslash with quote \" and hence your quotes don't close.
which shows that you have only one backslash with quote bracket \" and hence your quotes don't close.
