For the output variables, you have to run the simulation first then change the output variables in E+ or use OS measure.
If looking for PV energy generation, NREL PVWatt's calculator is a good choice.link text
If you try to see how to model with OS or E+, please refer to this question link text
Hope this helps.
For What are you trying to get from the output variables, you have to run the simulation first then change the output variables in E+ or use OS measure.
If model ? if looking for PV energy generation, NREL PVWatt's calculator is a good choice.link text
Hope this helps.
