You should be able to model this by using Daylighting:Controls
object and setting required Illuminance setpoint values at reference point(s). Lighting energy consumption will also depend on the Lighting control type i.e. continuous, stepped or continuous/off. Also, make sure that you modify Fraction Replaceable
field of Lights
object.
object and object, setting required Illuminance setpoint values at reference point(s). Lighting The lighting energy consumption will also depend on the Lighting control type i.e. continuous, stepped or continuous/off. Also, make sure that you modify Fraction Replaceable
field of Lights
object.
