Using the example file 5ZoneCAV_MaxTemp and running an annual simulation with no other changes to the file also causes max iteration warnings, although these were from SolveAirLoopControllers. We are beginning to look into these issues and I will add this file to the list of problem files. I suggest you add your file as well so we correct as many of these issues as possible.
