Check out the inputs to the WindowMaterial:Glazing and the EnergyPlus Engineering Reference description of the Window Calculation Module. DesignBuilder uses EnergyPlus as the simulation engine, so the spectral data you're inputting is likely being used for complex fenestration calculations in EnergyPlus.
