You may want to look at the Zone Component Loads Summary which can be output when the Output:Table:SummaryReports, see:
http://bigladdersoftware.com/epx/docs/8-4/input-output-reference/output-table-summaryreports.html#zone-component-load-summary
Unfortunately, it only produces two of the twelve months that you are looking for. I suppose it could be repeated six times using different design day periods for six different simulations. A description of how the Zone Component Loads Summary is created is described in:
http://bigladdersoftware.com/epx/docs/8-4/engineering-reference/zone-component-loads-summary.html#zone-component-loads-summary
It also talks about the difference between space heat gains and loads. I would encourage you to review that section to see how the loads are estimated.
