Make sure you have defined a zero offset temperature: see this
Also, you need to add a setpoint manager to the outlet of the HX on the chilled water side, or create your own plant loop equipment operation scheme (see this)
Here's how the chilled water loop should look like (unless you choose to define your own plant equip operation scheme)
