I agree there is room for improvement. However, the defining characteristic of OpenStudio is that it's not simply an application but a SDK with an API that can be used to automate repetitive tasks through formal measures or directly from a terminal. Also, there are several existing built-in features to speed up repetitive tasks.
Thermal Zones
The Apply to Selected
feature can be used to add zone equipment to multiple zones. For example, adding a FanZoneExhaust to all zones. However, the steps are not intuitive (Multi-Edit Grid View video).
- Select zones using the check box.
- Click a zone equipment object name to select the type to apply to other zones, which will turn yellow.
- Click the Apply to Selected button at the top of the column.
HVAC Systems
The AirLoopHVAC:ZoneSplitter
object can be usesd to quickly add zones to an air loop and will magically add air terminals to the zones if there's already one assigned.
Also there are several existing built-in features to speed up repetitive tasks.
Thermal Zones
feature can be used to add zone equipment to multiple zones. For example, adding a FanZoneExhaust to all zones. However, the steps are not intuitive (Multi-Edit Grid View video).intuitive.
HVAC Systems
Thermal Zones
feature can be used to add zone equipment to multiple zones. For example, adding a FanZoneExhaust to all zones. However, the steps are not intuitive.
HVAC Systems
The
object can be usesd to quickly add zones and air terminals to an air AirLoopHVAC:ZoneSplitterZoneHVAC:ZoneSplitterloop and will magically add air terminals to the zones if there's already one assigned.loop.
Also there are several existing built-in features to speed up repetitive tasks.tasks.
Thermal Zones
HVAC Systems
The ZoneHVAC:ZoneSplitter
object can be usesd to quickly add zones and air terminals to an air loop.
