Do you want the IdealLoadsAirSystem to meet the cooling load? Depending on your setpoint temperature, that may not be possible with 21 C supply air. If you want to model a dedicated outdoor air system (DOAS) that always delivers air at 21 C and has different flow rates during cooling and heating, you might need to build up an AirLoop system.
