ReadVarsESO is the program that extracts from the eso database and creates the csv file. So if E+ isn't able to run that file, you're not going to be able to get your csv variable output.
To troubleshoot it, you can try creating a folder and copying the files titled ReadVarsESO.exe and RunReadESO.bat into it (both found in the EnergyPlus PostProcess directory).
Then find the eplusout.eso file in the EnergyPlus folder of your simulation output and copy that into the same folder with the executable and the batch file.
Run the batch file and a csv document will be created in the same directory.
If that doesn't work, I'm not sure what to tell you other than reinstall EnergyPlus. Maybe someone else can provide more insight.
ReadVarsESO is ReadVarsESO.exe the program that extracts from the eso eso database and creates the csv csv file. So if E+ isn't able to run that file, you're not going to be able to get your csv variable output.
To troubleshoot it, you can try creating a folder and copying the files titled ReadVarsESO.exe "ReadVarsESO.exe" and RunReadESO.bat "RunReadESO.bat" into it (both found in the EnergyPlus PostProcess directory).
directory. Then find the eplusout.eso "eplusout.eso" file in the EnergyPlus folder of your simulation output and copy that into the same folder with the executable and the batch file.
file. Run the batch file and a csv document will be created in the same directory.
If that doesn't work, I'm not sure what to tell you other than reinstall EnergyPlus. Energy Plus. Maybe someone else can provide more insight.
