I might append to this approach to consider adjusting boosting thermal mass in the associated space(s), and also inputs for baseboard dT, pressure drop, and baseboard loop operation to more accurately reflect the operation of the radiant slab system. Note as well you could set up an expression to calculate capacity based on the local SPACE AREA, which could save a lot of user error potential (and time)!
