ChillerHeaterClgEIRFT should also be set to constant 1. Also reporting frequency should be set to detailed as hourly frequency aggregates the output value for an hour.
ChillerHeaterClgEIRFT should also be set to constant 1. Also reporting frequency should be set to timestep or detailed as hourly frequency aggregates the output value for an hour.
