Here are two more tools you might look at:
NREL's Model Maker takes simplified inputs, makes assumptions to expand the inputs to make a detailed EnergyPlus model, runs the model, and gives you back the results.
The eQuest Schematic Design Wizard takes simplified inputs and makes assumptions to expand the inputs into a detailed DOE-2 model.
