Here's an answer using eppy which might not be what you're looking for but might help someone in the same situation in the future.
from eppy.modeleditor import IDF
in_file = "eppy/resources/idffiles/V8_1_0/Boiler.idf" # the path to your IDF
idd = "eppy/resources/iddfiles/Energy+V8_1_0.idd" # or whatever IDD version you're using
IDF.setiddname(idd)
with open(in_file, 'r') as infile:
idf = IDF(infile)
# get the surfaces in the model, filtered by having Outdoors as the boundary condition
surfaces = [s for s in idf.idfobjects['BuildingSurface:Detailed'.upper()]
if s.Outside_Boundary_Condition == 'Outdoors']
total_external_area = sum(s.area for s in surfaces)
# get the glazing surfaces to remove from the total external areas
glazing = idf.idfobjects['FenestrationSurface:Detailed'.upper()]
total_glazing_area = sum(g.area for g in glazing)
# calculate the external areas by orientation
area_by_orientation = defaultdict(float)
for s in surfaces:
surface_area = s.area - sum(g.area for g in glazing
if g.Building_Surface_Name == s.Name)
area_by_orientation[s.azimuth] += surface_area
# print the results
print "Areas by orientation"
for area in area_by_orientation:
print "%s: %.2f m2" % (area, area_by_orientation[area])
print
print "Total area: %.2f" % total_external_area
print "Total glazed area: %.2f" % total_glazing_area
0.0: 125.77 m2
90.0: 28.80 m2
180.0: 33.60 m2
270.0: 30.72 m2
Total area: 226.58
Total glazed area: 7.68
Here's an answer using eppy eppy which might not be what you're looking for but might help someone in the same situation in the future.
IDF.setiddname(idd)
idf = IDF(infile)
for s in surfaces:
# print the results
print
0.0: 125.77 m2
90.0: 28.80 m2
180.0: 33.60 m2
270.0: 30.72 m2
Total area: 226.58
