The thermostat temperatures are set using schedules. In your IDF you most likely have one or more ThermostatSetpoint:DualSetpoint objects (docs). These in turn will refer to a schedule which can be any kind of schedule object.
The simplest way to set the same setpoint all across the year is to set up one Schedule:Constant (docs) for your heating setpoint and another one for your cooling setpoint.
