The source code is hosted in the EnergyPlus repository on GitHub. If you're unfamiliar with distributed version control using Git, then learning about that is a mandatory prerequisite. As far as I know most of the information for developers is in the Wiki section of the EnergyPlus repository.
  1. Git Documentation
  2. Developer Information
