The OpenStudio GUI supports only supports adding specific component types (Materials, Constructions, and Ductless Heat Pumps). This is done via the "Components and Measures / Find Components" menu item.
The API can access any kind of component on the BCL. This is demonstrated in the Get BCL Weather File user script in the sketchup plugin.
I have a few unpublished measures that exercise the api (One to get site components, another to get construction). I'll see if I can get one of these posted on BCL as en example The trick to using a measure that accesses BCL components is planning it in a way so that the search results that populate the choice list are not too long. The user script can iterate (e.g. first pick city, then pick from sub-set of weather files for that city). A measure has to do it in one pass.
Here is a short snippet if you already know the UID of the component you want.
# download from BCL
remote = OpenStudio::RemoteBCL.new
remote.downloadComponent(uid)
component = remote.waitForComponentDownload()
if component.empty?
runner.registerError("Cannot find local component")
return false
end
component = component.get
# get osc file
files = component.files("osc")
if files.empty?
runner.registerError("No file found")
return false
end
construction_path = component.files("osc")[0]
construction_file = OpenStudio::IdfFile::load(construction_path)
vt = OpenStudio::OSVersion::VersionTranslator.new
constructionComponent = vt.loadComponent(OpenStudio::Path.new(construction_path))
# get model object
if constructionComponent.empty?
runner.registerError("translateSurfaceConstruction: Cannot load construction component '#{construction_file}'")
return false
else
object = constructionComponent.get.primaryObject
if object.to_Construction.empty?
runner.registerError("translateSurfaceConstruction: Construction component '#{construction_file}' does not include a construction object")
return false
else
componentData = model.insertComponent(constructionComponent.get)
if componentData.empty?
runner.registerError("translateSurfaceConstruction: Failed to insert construction component '#{construction_file}' into model")
return false
else
new_construction = componentData.get.primaryComponentObject.to_Construction.get
end
end
end
Here is the entire run section of a measure that creates model objects from all the OSC files from a "resources" directory within the measure.
# define what happens when the measure is run
def run(model, runner, user_arguments)
super(model, runner, user_arguments)
# use the built-in error checking
if !runner.validateUserArguments(arguments(model), user_arguments)
return false
end
# report initial condition of model
runner.registerInitialCondition("The building started with #{model.numObjects} objects.")
# get all objects in directory
files = Dir.entries("#{File.dirname(__FILE__)}/resources/")
files.each do |new_object|
next if not new_object.include?(".osc")
runner.registerInfo("importing component from #{new_object}")
#load the osc file
new_object_path = OpenStudio::Path.new("#{File.dirname(__FILE__)}/resources/#{new_object}")
new_object_file = OpenStudio::IdfFile::load(new_object_path)
if new_object_file.empty?
runner.registerError("Unable to find the file #{new_object}.osc")
return false
else
new_object_file = new_object_file.get
end
new_objectComponent = vt.loadComponent(OpenStudio::Path.new(new_object_path))
if new_objectComponent.empty?
runner.registerError("Cannot load new_object component '#{new_object_file}'")
return false
else
object = new_objectComponent.get.primaryObject
componentData = model.insertComponent(new_objectComponent.get)
runner.registerError("Failed to insert new_object component '#{new_object_file}' into model")
return false
else
new_new_object = componentData.get.primaryComponentObject
end
end
end
# report final condition of model
runner.registerFinalCondition("The building finished with #{model.numObjects} objects.")
return true
end
# download from BCL
if component.empty?
return false
end
# get osc file
if files.empty?
return false
end
# get model object
return false
else
return false
else
return false
else
end
end
end
return false
end
#load the osc file
return false
else
end
return false
else
return false
else
end
end
end
return true
end
# download from BCL
get component
if component.empty?
return false
end
# get osc file
if files.empty?
return false
end
# get model object
boject
return false
else
return false
else
return false
else
end
end
end
# get component
if component.empty?
return false
end
# get osc file
if files.empty?
return false
end
# get model boject
return false
else
return false
else
return false
else
end
end
end
if component.empty?
return false
end
# get osc file
if files.empty?
return false
end
return false
else
return false
else
return false
else
end
end
end
