The measure JSON format is being deprecated in preference to the XML one because the BCL accepts XML only. Probably the easiest thing to do is use the OS App to make a new measure, then copy your measure.rb over. You may have to edit a few fields in the XML by hand but it wouldn't be too bad for a few measures.
