It depends what you're trying to do.
If you just want to access the openstudio-standards gem to use its methods in your own measures, then you just have to install the gem and include
require 'openstudio-standardsat the top yourmeasure.rb.If you want to modify the openstudio-standards itself, then you should check out the docs, specifically the Developper Information page on github or on rubydocs
