Are you using any apostrophe's in zone names? May be related to this issue.
If you upgrade to OpenStudio 1.10.0 or later it will trap this error and you will see the rest of the report except for the Zone Conditions section. Or if you rename your thermal zones then you can re-run and the error should go away.
The issue is caused by sql query's with some non- alphanumeric characters. Here is a similar post but with design day name instead of thermal zone name.
Are Also are you using any apostrophe's in zone names? May be related to this issue.
