I am afraid that if there is not already a suitable EMS actuator which provides a hook into the model's calculations, then EMS cannot really be used to alter an existing model. EMS can create new output variables but it can only modify the results showing in an existing output variable if there are suitable actuators that can override the program’s calculations.
You could make a user-voice request that the specific actuator you want be added to ElectricEquipment:ITE:AirCooled. (Or take advantage of the open-source code and add the EMS actuator yourself.)
